when i want to turn on VR via oculus link cable not going what happens this i don't know what about
Eduard.eda20
Oculus Community Manager
Hey Eduard.eda20,
We see that you are having issues with Air Linking on your device. Don't worry, we're here to help get you in the right direction for troubleshooting and back to gaming!
Please refer to this Oculus Support article for Oculus link compatibility to help determine if you have the accurate setup for the best experience -  https://ocul.us/3BJ7wGi
If you find that you meet the link requirements, follow the troubleshooting instructions below:
  1. Open the Oculus app on your PC.
  2. Turn on your Quest 2 or Quest.
  3. Plug your USB 3 cable into a USB 3.0 port on your PC, and then plug the other end into your headset.
  4. A message displays in VR prompting you to Allow access to data. Select Deny. If you mistakenly 'Allow' the prompt, you must unplug your USB cable from the Quest and plug it back in.
  5. When prompted to Enable Oculus Link, select Enable to begin remote rendering using Oculus Link.
If after attempting the troubleshooting steps, you still experience the same issue, please submit an Oculus Support ticket. - https://ocul.us/3ves3Ac
Have a great weekend! 😎
