wich gpu for occulus q2 link best bang for buck compatible with linux
oculuslover8383
HI
Things have changed sinced i looked at pc.
Im on a budjet iwant best bang for buck that will be kind of futurproof
Utilisation Virtual reality OCCULUS quest 2 LINK plugged in
i dont do much video editing and the graphic card i would like is one than is more than sufficent for occulus quest by link but i dont want to overkill it. If possible one not to noisy cause it can suck
Other thing is that ill dual boot so the gpu have to be working well with linux.
Could you guys tell me if i should change a component for wich and why
i have a antec cp 850 that i will continue using cause it is still good and though and i goes in my
antec p183 case from 2008
see pic canadian dollar
<blockquote class="imgur-embed-pub" lang="en" data-id="As5PzzT"><a href="https://imgur.com/As5PzzT">View post on imgur.com</a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
Amd ryzen 5 3600 3.6 6core 249 cnd
msi b 450 gaming plus max atx am4 134 cnd
artic freezer 34 esport duo cpucooler 79 cand
corsair vengeance lpx 16g 2x8 ddr4 3200 cl16 119 cnd
0 REPLIES 0
