Help
Alessiodido
The More settings option isn't on my oculus app and I'm trying to turn on developer mode on
Hi, I posted last night where/how I finally found settings here. Hope it works for you!
Option_VR
I was experiencing the same problem when using the Oculus app on my Android phone, no option for developer mode anywhere!
I then factory reset the headset and tried again with the Oculus app on a iPhone, after connecting the headset it worked just as GrayfeathertheOwl has described (had to scroll up to find 'Developer Mode' as the options are hidden beneath).
Try again on an Apple device and see if that works. Good luck!
