Unreal Project Settings
remoz
Has anyone a preset or template for Oculus Quest 2 Unreal Project Settings?
  • One that works with Vulkan
  • One that works with ES3.1
After following the official Oculus guides and also the Unreal guides I am always getting errors.
I can't seem to build one functional Unreal UE4 project, that I can launch on the Quest 2.
Thanks for any little help,
appreciate it!
https://FattyBull.com
3 REPLIES 3
Ciberspy
Are you able to do a VR preview through link cable?
remoz
yes. It's a bit crazy what you have to do in order to get it all set up and work properly.
If you have the Quest 1 up and running with the initial drivers it doesn't work for Quest 2.
It requires a new installation, I am going to post the whole Oculus Quest 2 Setup for Unreal on my blog:
https://FattyBull.com/blog/
Ham1ton
I found that it's all about your android SDK and NDK settings. What are your android built settings?
