2 Question about the Rift S. Audio & Games, more.
TomTom1298
Dear.
A few questions :smile:
Does the Oculus Rift S support my bluetooth headset?
I know the Rift S has a 3.5 mm port for audio. But my headset has a BlueTooth-Station, connected with my PC. Is there any changes that i can use the Rift S with my default Windows Audio?
Is there any list of games that support the Rift S?
And, if i pre-order now. Do i pay when the Rift S is being shipped to me (24 may for NL) or directly when i pre-order it?
Thank you! 🙂
My PC-Specs:
I7 8700k - 16Gb DDR4 3200 Ram. (2x8) - RTX 2080 Ti
ShocksVR
Level 9
I don;t know about your bluetooth questions.
But regarding games, the Rift S plays all the Rift games and vice versa (Rift can play Rift S games).  Rift S also plays games from STEAMVR.
i7-7700k, Zotac RTX 3080 AMP Holo (10G), Oculus Quest 2
Previous: Oculus GO, Oculus RIFT - 3 sensor Room-scale, Oculus Rift S
nalex66
Volunteer Moderator
Volunteer Moderator
The Rift S doesn’t directly connect with Bluetooth headphones, but you can use audio from your PC, including headphones connected to your PC. You may not get the same quality of 3D spatial sound, since that’s processed on the headset.
If you order from Oculus, they charge your credit card when they ship. I’m not sure about other payment methods—in the past, they charged immediately if you used PayPal.
i7 5820K @ 4.25GHz | RTX 3080 Ti FTW3 | Gigabyte GA-X99-UD4 | Corsair DDR4 3000 32GB | Corsair HX 750W
