2080 is not in recommend why?
reprover
Honored Guest
7 REPLIES 7
jbark51
Honored Guest
Card is newer than the last Oculus update or they forgot to add it to the list.
reprover
Honored Guest
but I will see the tip on vr all the time, it's so bad
Shii
Protege
I have MSI RTX 2080 and don't have any warnings about incompatible GPU in VR.
Intel Core i7-7700K, Asus ROG Strix Z270E Gaming, 32Gb RAM, MSI RTX 2080 8Gb Gaming X Trio
reprover
Honored Guest
It's so confused.. Mine is Colorful
Digikid1
Consultant
That makes no sense whatsoever.
nrosko
Superstar
send them an email if you are worried but i'm 99.9% its nothing to worry about & it will work fine.
RedRizla
Honored Visionary
Not sure what you mean by this tbh. Contact oculus Support because that Graphics Card should have no problems.
