Audio Crackling
AlexNewmanUK
Hoping someone can help me out as I stuck.
Audio through my rift S headset is crackling, I have tested the headset in my friends pc and it works fine.
I have tried:
disabling other sound devices
updating all drivers for oculus / graphics card
updating usb sound drivers
Uninstalling devices in device manager etc.
Crackling only occurs on my rift speakers on usb sound card are fine.
I have a startech usb 3.0 pci card, the rift is the only thing attached to it.
It was all working fine until a few weeks ago.
ao1977
Do you happen to have a 5XX series AMD motherboard? Then try this: https://forums.oculusvr.com/community/discussion/98164/got-a-b550-or-x570-motherboard-and-usb-issues-with-the-rift-s-try-forcing-pcie-3-0
Hardware (Living Room Setup)
Sim-Plicity SW8C+ Direct Drive Wheelbase | 3DRAP.it Formula Rim w/ Simhub Dashboard | Thrustmaster T-LCM Pedals
Playseat Challenge
Silverstone RVZ01B-E | ASRock B550M-ITX/ac | AMD Ryzen 5 5600X | Gigabyte RTX 3070 Eagle OC 8G | 50" UHD TV | Oculus Rift S
