Changing start location in Home
vfrhawk
Can't decide if I'm being dense not seeing how to do this, or if its not possible, but how do you change the position you're standing in when Oculus Home loads?  I want to be staring out at the grand expanse of the universe, not looking at the wall when I spawn in!  🙂
Related.  Can you also have home go straight to your chosen environment rather than loading dash and then after a few moments loading your home environment?
VFRHawk
Richooal
Level 12
Load "Home"
Go to where you want to be when you start "Home"
Press the Left Controller "Menu Button"
Go to "Places", "Your Homes"
Click on the home you want to set the position in
Click on the 3 Dots ...
Click on "Set Entry Point"
VFRHawk
You can hit the Right Touch "Oculus Button" while everything is loading, and it will cancel the Dash stuff and go straight to "Home".
I changed this entry point location and now that home will no longer load. No other changes were made, just the entry point. I have a ticket in now with support to hopefully reset it back to default on the server.
