Your RAM is fine.
Your CPU is right on MINIMUM spec for Rift S.
Your GPU is below MINIMUM spec for Rift S.
If you really want to get into VR, but you're on a budget, go for the Quest 2. No PC required to run lots of quality VR stuff. When you're ready to upgrade your PC it will be able to run Rift games on the Quest using "Link".
If you really must go in at the bottom end and use the Rift S, you are going to need to do a full CPU/GPU upgrade.
The link shows you the minimum cards required and the recommended ones too. You can Google the prices.................
https://support.oculus.com/4002430699785546
