01-12-2020 03:37 PM
At first I thought my display port was broken but then it detected the headset for around 5 seconds as I moved on to set up the controllers it couldn't detect it anymore. I also youtubed then problem and found many other people in dec 2019 and jan 2020 have had the same problem.
So im 99% sure its not my grpahics card thats the problem. Ive googled to try and find a firmware update but nothing has come up at all.
Im honestly getting frustrated and want to refund the thing, ive been up for hours trying to fix it and still nothing, Windows is up to date, Nvidia is up to date, Oculus is up to date EVERYTHING IS UP TO DATE yet nothing. Ive tried restarting my computer, waiting 5 seconds to put the display port in after, removing the putting back the display port in the headset itself yet nothing.
I just wanna play beat saber man. Has anyone else had this problem or knows how to fix it?
01-17-2020 09:05 PM
01-18-2020 12:35 AM
ZaroktheImmortal said:
I've had a similar issue since buying it where it'd tell me it can't find the display port or tell me to reset the software or it'd tell me it can't find the headset then I'd go about unplugging it and plugging it back in helps I have to go through pretty much every day of a rinse repeat of unplugging plugging back in restarting my computer and going through different methods until it works for that day I contacted support about it and got told they are aware of the issue and are looking into a fix but have no time frame on a fix.
04-03-2020 04:50 AM
04-03-2020 02:43 PM
02-25-2021 11:49 AM
hi i have the same problem. one day after 4 months the display port would not connect. i have tried different ports on graphics cards with no joy.. have tried re- connecting both leads to no avail. how did you sort this problem out? i reformatted my hard drive but to no avail. display port still not connecting. if you could help it would be much appreciated.
cheers.
