DisplayPort
Kda_rekt
My Oculus Rift S want go on because My DisplayPort wan't connect i've Tried Everything i know and it dont work  pls help me
Caradavin
I'm having the same issue. Brand new Rift S. Displayport connection detector keeps spinning and spinning like it's not there.
Sheepgamer2000
It's not recommended using DisplayPort. it might be a poor connection between the motherboard the the DisplayPort itself, or you're using a older port which can more of less only connect to screens/monitors. I recommend using the mini-DisplayPort which comes with the headset because of it's better connection to the computer and software
