Every 5-30 minutes there is a restart (Crash) of Oculus Dash.
Animeshnick2.0
Every 5-30 minutes there is a restart (Crash) of Oculus Dash, I tried to reinstall Windows, reinstall Oculus, follow the instructions for completely removing Oculus, followed the instructions for removing the connector on the helmet and computer. NOTHING CAN HELP, I hope for your help.
Specifications:
-CPU: i5-11400
-GPU: MSI RTX 2060 Super
-MB: MSI MAG B560 TOMAHAWK WIFI
-RAM: 16GB 3200mhz
-OC: Windows 10(Home, Lastest)
-M.2 SSD 4.0 512gb
-HDD: 1TB+1TB
TomCgcmfc
Level 15
Maybe try the latest nvidia 496.13 driver.  Seems to work great for me.  If you are on anything much older you are best to use DDU to properly uninstall the older driver beforehand.  Also try to avoid any bloatware like geoforce exp or msi afterburner.  Good luck mate and cheers.
Edit; Also make sure you do not have any power saving enabled with any of your usb's.
