How to change left/right view offset?
DEGEILEN
How can I change the distance between the left and right view renders?
I want to move them closer together.
Crazy_Sane
Level 8
Are you asking from a software development perspective? Then you should've posted this question in the developers forum.
If you're asking as an end user, I believe the software IPD should be adjustable in the device settings. I must admit I dont have experience with the Rift S, but I know Windows MR has the option to change it.
