Lone Echo constantly crashing please help
bportjoey
[6-15-2019] [21:14:56]: === System Info ===
[6-15-2019] [21:14:56]: CPU: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
[6-15-2019] [21:14:56]: Num Physical Cores: 8
[6-15-2019] [21:14:56]: Num Logical Cores: 8
[6-15-2019] [21:14:56]: Memory: 32 GB
[6-15-2019] [21:14:56]: Process Committed Memory: 6137 MB
[6-15-2019] [21:14:56]: Process Peak Committed Memory: 6588 MB
[6-15-2019] [21:14:56]: Process Working Set: 2512 MB
[6-15-2019] [21:14:56]: Process Peak Working Set: 2512 MB
[6-15-2019] [21:14:56]: System Committed Memory: 15189 MB
[6-15-2019] [21:14:56]: System Max Committed Memory: 37804 MB
[6-15-2019] [21:14:56]: System Physical Memory Used: 7190 MB
[6-15-2019] [21:14:56]: Video Card: NVIDIA GeForce RTX 2080
[6-15-2019] [21:14:56]: Driver Version: r430_00 (43086)
[6-15-2019] [21:14:56]: Dedicated GPU Memory: 8010 MB
[6-15-2019] [21:14:56]: A crash was detected while running thread: Task Kernel
[6-15-2019] [21:14:56]: [Aggregated 1 times] Unblocking monitored fence
[6-15-2019] [21:14:56]: [Aggregated 1 times] CliD3D11CompositorClient::release 1
30 REPLIES 30
Saufy
same happend to me 😞 It's crashs after 20 minutes
dburne
Level 16
Same here - have not been able to run Lone Echo since getting my Rift S. Tried it with CV1 and same result also.
Mine crashes to desktop after about 5-10 minutes.
Saufy
i have crash with revive / Vive Pro and with Oculus Rift
RuneSR2
Level 16
My son played it for about an hour two days ago - no problems, all settings maxed apart from MSAA. CV1 1.37 - Forceware 4.17.
bportjoey
Perhaps the game isnt optimized for rtx cards?
Saufy
I solved it!
I put down the Graphic.... Temporary AA off, and all on medium. Now it works!
bportjoey
I figured out my issue, I had a bad over clock on my CPU. The game runs flawless with Max settings even with SLI enabled
bportjoey
Are you overclocking your CPU? If so try adjusting that, that was my issue game runs like a dream now for me
Saufy
I had overclocked my cpu too but tried default setting... same issue, only lower settings soved it. And i had 90FPS with highest settings. 8700k and RTX 2080 TI
