Showing results forย
Search instead forย
Did you mean:ย
My controllers are stuck in the ground (i think) together, and will only rotate on the spot.
de_lounge
I've had this problem for about 4 weeks, i have tried to fix the problem through removing the batteries, disconnecting the controllers, restarting my Oculus, trying different games countless times, and looking through forums posts. Nothing has worked.
I can't even set the floor level, let alone the play area.
If anyone has a fix I'm willing to listen.
0 REPLIES 0
