04-26-2020 04:23 AM
04-26-2020 10:32 AM
04-26-2020 10:41 AM
04-26-2020 12:12 PM
04-26-2020 12:25 PM
You could try adding the game manually using the desktop Oculus software (the + at the top of the library), Then edit the json files, you should end up at the same result, I'll add the json file contents here just in case things get messed up!
nalex66 said:
Edit: Well, first hurdle--there are no json files in there for NMS, although there are json files for other recent games that don't appear in my Oculus library (namely GZDoom OpenVR mod). Tried launching NMS from within the Oculus desktop mode, but it just launched the game on the desktop rather than in VR, and still didn't create any json files. I'll mess around a bit more and see if I can get it to generate the files. I normally launch the game from within SteamVR Home, but I do the same for all SteamVR games, and other recent ones like HL:A and Boneworks do have library icons.Edit 2: Played the game in VR, still no new json files. When I hit the Oculus menu while playing, it indicates that I'm playing SteamVR. I'll have to google the way to launch the game in VR without doing it from within SteamVR Home--there is likely a Steam launch option to force it. If I can do that, maybe Oculus will recognize the game while it's being played and create the files.
04-26-2020 12:42 PM
04-26-2020 01:18 PM
