No audio in Elite Dangerous
johnmckav
Hi I've just got the Rift S and it works perfectly with Steam and Oculus games except for Elite Dangerous.
ED is installed from Frontier "not steam" and I've been playing it for years without issue.
Now when I play it in VR it works perfectly except no audio.
I've checked settings in both W10 and Elite and I think everything is as it should be.
Any ideas please?
3 REPLIES 3
AngryKFP
Did you make sure to change the windows sound output to the rift? Otherwise it'll be outputting to the default device which wont be the rift. You can easily change it by left clicking the volume icon in the tasktray and then using the drop down list above the volume slider.
RattyUK
Level 10
Elite: Dangerous native in Oculus normally 'forgets' to change device to the HMD for sound, in steamVR ensure that it is set to switch to HMD audio/mic and return to default (speakers in my case) when steamVR exits.
Native Oculus, as suggested above, prior to playing ED switch your audio to HMD - then revert as needed wnen finished.
PC info: AMD Ryzen 7 2700X, MSI MPG X570 Edge, 16GB Tforce Pro Dark DDR4 3200, KFA2 RTX 2080 Super, Samsung 870 Pro M.2, 2x 240GB SSD, 3TB WD Green HDD & 4 TB Seagate Barracuda HDD, Antec Modular 750w PSU, custom watercooling loop. (Win 10 Pro & Opensuse Leap 15.1 Linux) 32" AOC 4K Monitor.
Rift S
Laptop: Aorus X5 V6-CF1 (I7-6820HK, GTX 1070, 2* 256GB M.2 NVME, 1TB 7200 HDD)
johnmckav
Thanks that's sorted it. What a forum
