No enciende luz blanca en el casco y 0 imagen , alguna solucion??
MarceChucky
Buenas, les agradeceria la ayuda para resolver este problema  que me tiene loco, resulta que compre un ordenador portable nuevo Asus tuf Amd ruzen 9 , rtx 2060 y 32gb y cuando instalo oculus rift se queda en el momento de calibrar el casco y NO SE VE NADA Y SOLO HAY UN LED COLOR NARANJA, lo probe en mi antiguo ordinador portable con carta grafica gtx 1050 y enciende normal ( la imagen es muy mala porque no tiene las especificaciones minimas pero enciende!!!) Ya actualice todo lo aue pude, BIOS, Windows, carta grafica, oculus, .... en fin, hasta ya he reinicializado Windows de 0 2 veces.
Muchas gracias por la ayuda.
Que tengan un buen dia.
RuneSR2
Level 16
Google Translate is your friend:
Good, I would appreciate the help to solve this problem that has me crazy, it turns out that I bought a new portable computer Asus tuf Amd ruzen 9, rtx 2060 and 32gb and when I install oculus rift it stays at the time of calibrating the helmet and I DON'T SEE NOTHING AND THERE IS ONLY ONE ORANGE LED, I tested it on my old portable computer with a gtx 1050 graphic card and it turns on normal (the image is very bad because it does not have the minimum specifications but it turns on !!!) I already updated everything I could, BIOS , Windows, graphic card, oculus, ... Anyway, I've even rebooted Windows 0 2 times. Thank you very much for the help. Have a nice day.
Intenta enviar un ticket a Oculus Support   o:)
https://tickets.oculusvr.com/hc/en-us/requests/new
i7 7700K (4.5GHz); MSI GTX 1080 8GB Gaming X (oc 2100MHz gpu boost, 11GHz mem speed); 16GB 3200MHz; MSI Z270I (VR-Ready) mainboard; Samsung 961 NVMe 128GB (OS) + Samsung 860 4TB SSD (games) + Toshiba P300 HDD 3TB (games); Win10; Valve Index and Oculus Rift CV1 using super sampling 2.0.      "Ask not what VR can do for you – ask what you can do for VR"
