Showing results forΒ
Search instead forΒ
Did you mean:Β
Not PC Savvy - Need Help
MackAttack1652
I'm interested in getting the Rift for my current PC but I'm not too sure if my PC is Rift compatible - HP 800 G1 SFF, i5 @ 3.2GHz, 16GB RAM, 180GB SSD + 500GB, Win10 Pro, NVIDIA GT 1030 2GB. Those are the specs of my computer from the website I bought it from. My PC is able to run Sims 4 very fast and smoothly all DLC's included, plus House Flipper and Cooking Simulator very good as well. My boyfriend can also play League of Legends good if any of this helps. TIA πŸ™‚
Richooal
Level 12
The GT 1030 is well below minimum requirements for the Rift or Rift S.
From this link.........
https://support.oculus.com/1225089714318112/
