After updating Oculus firmware to 1.8 my Oculus Integration plugin controller inputs are not working anymore. I reinstalled the Oculus software and updated the latest Nvidia GPU driver as well. Also, I included OVRInput.Update() before all OVRInput.Get calls and it still doesn't work. Are there anything else I can try to make this work?
Same here. I was on my last tweaks before production push and now the forefinger and side buttons don't register, but X and A do with some axis tilt. I was going to start debugging code but then I caught this. Thanks, you just saved me a lot of research. I don't know what to do except wait for Oculus to respond in some fashion. I was so done too.
I am in the same position as phyzxengr the final stage of my app is to use the A button to reset some blocks, none of the buttons are working for me except trigger.
Get Help
