03-04-2021 09:43 AM
I operate Prepar3dV5 through Oculus Client but Oculus Client does not run P3D with Admin rights - needed to operate some of the P3D functions. Is there a way to cause Oculus Client to run P3D with Admin rights?
Thanks
Warren
03-07-2021 07:26 AM
Don't launch from oculs software,Go where program is installed, find exe file, right click, esec as admin.
03-07-2021 11:06 AM
If i launch outside Oculus Client the program works correctly but the VR doesn't work at all.
03-07-2021 11:32 AM
See the propriety of file, and check Always run as administrator.
Now launch from oculus.
03-07-2021 11:49 AM
If I set the program in the .exe to always run as administrator then the program will not launch in Oculus Client.
I can launch the program without Admin rights through Oculus Client and have some parts of the program not work correctly or I can assign Admin rights to the program and have the program work correctly but not have VR
appreciate your suggestions. I need to find a way to have Oculus Client launch the program with Admin rights.
03-07-2021 12:23 PM
Sorry, my bad.
you have to launch oculus software with admin right. hope this solve the problem.
03-07-2021 12:33 PM
Hello
I always launch Oculus Client with admin rights but it does not in turn launch my program (P3Dv5) with admin - at least so far I have not been able to do this. I need to cause Oculus Client to launch my program (P3Dv5) with admin rights.
03-07-2021 01:28 PM
So client is with admin, but dash?
Do this step:
Close oculus app,and oculus service.
check the install folder of oculs,you have many subfolder.
Find
oculus-platform-runtime.exe and OculusDash.exe
grand admin privileges to these file.
launch oculus again.
this worked for me.
03-07-2021 02:01 PM
Hi
I found both files but neither allows me to grant admin privileges. I see the option but I am not sure how to change this in a file which is not an .exe.
Thanks
03-07-2021 02:08 PM
Hi again
I was able to change the Oculus-platform-runtime .exe to run with admin rights but I have not found the Oculus-dash .exe.
Thanks
