Oculus Debug Tool - Asyncronous Spacewarp setting
markwest76
I use link (usb 3.0) for PCVR with a Quest 1 and was wondering why after I set the Asyncronous Spacewarp setting in the Oculus Debug tool to "disabled" and start the Oculus software, when I close the software the setting always gets back to "auto" (the same applies for 45 fps enabled/disabled)...in fact I can't change this settings because when I launch the Oculus software it always uses the "auto" setting.
Anyone knows why this is happening and if there's a fix? (I'm using Oculus software v. 29.0.0.48.528)
Thanks
0 REPLIES 0
