Showing results forย
Search instead forย
Did you mean:ย
Oculus Home2 crash after updated to PC App build 28
timorsohc
Hi, I'm using Rift S.
After updated PC App to build 28, I cannot run Oculus Home 2 anymore.
It keeps crash with continues circle cursor looping. The dashboard is fine, only cannot load Oculus Home.
Already tried to re-install it, but getting the same error. ๐Ÿ˜
is it possible to revert it back to previous Build (27 or 26)? ๐Ÿ™„
Cheers,
Timo
0 REPLIES 0
