Oculus Rift CV1 cable
AliceLunaStar
Does anyone know where I could get a spare headset cable as I only have one left.  I still have a 2-year warranty on it as well and Oculus are unable to supply or let me buy one.
Many thanks
18 REPLIES 18
Megalithik
Ebay is the only source for CV1 cables.  They've been out of production for 18+ months now at this point.
RuneSR2
Level 15
Don't worry about the cable if it works. Then you might worry more about the CV1 headphones, scratching the lenses, having a dead sensor, breaking the IPD slider in 58 mm position and smashing Touch into a wall.
Earth might soon be hit by a giant asteroid too  :#
AliceLunaStar
Ebay.co.uk have broken ones for £50! BROKEN CABLES!! WTF?! Most have been used or are very expensive for a second-hand cable....
AliceLunaStar
Don't worry about the cable if it works. Then you might worry more about the CV1 headphones, scratching the lenses, having a dead sensor, breaking the IPD slider in 58 mm position and smashing Touch into a wall.  :#
My sensors.lensens and DPI are ok and I'm lucky not to have smashed any controllers yet....I have some spare CV1 headphones anyway.
Nunyabinez
Level 8
I agree with Rune. I thought about buying a refurbished CV1 when they had them in stock, but when they are $299 and and a new Rift S is $399 it seemed like I was better off just getting a Rift S if my CV1 cable or something broke. The price is so high on replacement cable it isn't worth it. I love the CV1, but I certainly got my money's worth out of them when they finally die.
kojack
Volunteer Moderator
Volunteer Moderator
The wall is more likely to be the one coming out of that encounter worse off.
Not so with new Touch, but CV1 Touch could withstand a fair bit of punishment.
parsecn
Level 7
While I'm very well kicking a dead horse on this one, please take a moment to vote here @AliceLunaStar https://oculus.uservoice.com/forums/918556-oculus-rift-s-and-rift/suggestions/38506144-continue-selling-rift-cv1-cables
Megalithik
The petition is great in theory but the company that Oculus had making the cables went out of business so there are no more being made.  Bringing another company online to fabricate more cables is likely too expensive to be worthwhile for them.
RuneSR2
Level 15
Out of nowhere, some dude just received a cable from Oculus ... What are the odds ...
https://www.reddit.com/r/oculus/comments/i97xc8/just_received_a_free_cv1_cable_out_of_nowhere/
