Oculus Rift S black screen crashes and static noise
Makarua
I am having a problem with my new Oculus Rift S in which it
will black screen randomly and i will hear a static noise as it does this. The
system crashes on any game, and has been occurring at any time between 10
minutes after booting up the game, to 3 hours after booting up the game.
Sometimes when the crash occurs I get a windows notification saying that the
DisplayPort isn’t connected, but this doesn’t happen every time the system
crashes.
Options used to try and rectify the situation which have
failed:
Uninstalled and reinstalled the Oculus Software.
Repair the Oculus Software.
Uninstalled and reinstalled SteamVR.
Checked that SteamVR and oculus software are up
to date which they are.
Checked that Windows 10 is up to date which it
is.
Checked that my GPU driver is up to date which
it is.
Checked that USB drivers are up to date which
they are.
Tried every USB Socket on my laptop
Turned off Power Saving mode in Device Manager
for all the USB sockets.
Disabled USB selective suspend setting in the
Windows Power Options.
Checked the DisplayPort wire is properly
connected to my laptop
Checked that the DisplayPort wire connection in
the headset is connected properly.
Turned off Kaspersky
Turned off Razer Cortex Boost ( Which did stop
the SteamVR games lagging )
Ran the Oculus software in Administrator.
Turned the volume on the Oculus Rift S down to
20% ( As some websites stated that loud noises can cause this problem)
Restarted the Oculus Service.
Restarted the Oculus Runtime Service.
These are my Laptops specifications:
GPU : NVIDIA GeGorce GTX 1060
CPU: Intel® Core™ i7-7700HQ CPU @ 2.80GHz
Memory: 16GB
Motherboard: MSI  MS-1785
94 REPLIES 94
Rtas_
I have the same problem, except i hear a very high pitched buzzing before the ensuing black screen and tv static noise. Still waiting on a response from oculus support, however i believe it may have something to do with the latest oculus software update.
Makarua
What PC/Laptop do you have and what graphics card do you have ?
DewDurtTea
I have this exact same issue and have also tried most of the things OP has listed.
DRCGaming
The same thing is happening to me. Would be nice if there was a fix for this.
Balaurtheraptor
Same issue here. Only started happening about three weeks ago though. It has gotten really bad when playing Alyx.
VierVonKreuz
I started having these issues after I changed out my motherboard and processor about two weeks ago. I've tried the above fixes with no success, and wondering if it's a compatibility issue with the motherboard. My next step is probably going to be to buy a PCE USB expansion card and try running the Oculus through it.
My current specs are:
PRIME X570-P (AM4)
AMD Ryzen 5 3600X
16gig RAM
NVIDIA GeForce GTX 1070
I hope a fix is discovered soon so I can get through more than an hour of HL: Alyx without having to restart my software.
afunfun22
Same problem for me, it seems to be linked to a lot of stuff happening at once. I get this when I load into a new level in Half Life Alyx
Zacuter
same problem , Didn't have this problem before .. these very annoying me .. help can fix it soon
When I play for 30 minutes or an hour.
Sometimes it can play for four or five hours, and it will lose the display connection....
Andrewe1
Just so people are aware, there's another thread in the support section with some of us having the exact same problem:
https://forums.oculusvr.com/community/discussion/87567/oculus-rift-s-problems-sensors-cant-track-hea...
You guys are not alone, and it almost certainly is a software problem, not a hardware defect.
Oculus really screwed this product up. Right before the most important game in VR history.
