Oculus rift s wont let me switch my audio output
Winterjet97
Ever since I got my oculus rift s I haven't been able to use my own headset. It will only let me use the microphone on the vr itself. Does anyone know how to fix this?
Oculus Community Manager
Hi @Winterjet97, please check the setting in the Oculus software as well as the setting on Windows audio and see what the defaults are set to. If you need any further assistance, please open a support ticket with us here. Thanks!
Sheepgamer2000
if you click the volume button on the bottom of your screen press the "^" above the volume bar, you can change headset outputs. for the microphone, you go to settings(Win+I) - System settings - Sounds - and change the input to your designated microphone you wanna use, you can change the microphone to you headset's and also change the output aswell.
