OculusSetup not showing up after install location command prompt
AmazingMick
Hi. I use the command prompt as listed in the guide to change my install location, and at first, everything works well and the administrator window shows up as it should and I click yes. Then after I click yes the OculusSetup doesn't pop up automatically. When I manually go on the OculusSetup app after clicking yes that also doesn't show the install location going to my D drive, only my C drive.
AmazingMick
Ok. I solved this actually. I did C:\Users\USERNAME\Downloads\OculusSetup.exe /drive:D instead of C:\Users\USERNAME\Downloads\OculusSetup.exe /drive=D. Somehow that was the problem
