Recommend USB PCI express card for connecting the Rift S
MakaveliBM
I have a GEFORCE GTX 1070 someone told me it as to connect to gpu its a 8 pin
Umpa_PC
Level 8
On the back of the GFX card there is a connector called 'Display Port' . The Oculus cable plugs in to that.  The other cable is for a USB 3 port.  That's all you need to connect.
Windows 10 Home Edition Version 10.0.18363 Build 18363, Oculus version 17, Quest Version 17
