Red light in oculus rift s
Pavelpouble
but i'm not asking you to examine anything i just want to know what the flashing red light in my oculus rift s means ???????????????
8 REPLIES 8
Hello, thanks for reaching out! We're glad to help! The flashing red light usually means the battery needs to be checked or replaced. Let us know if you need anything else. Thanks! 🙂
Rift S? Battery?
Rift s Works by câble and as soon as I plug it in there is this red light ?
Hello, thanks again for reaching out! So sorry for the confusion. If you are continuing to see a red flashing light, we recommend that you try the following steps below:
  • Re-seat the cable
  • Reboot your Rift S
If these steps do not work resolved the issue, then we would need to look at your logs to investigate further. To do so, you may click here to follow steps to collect logs and then click here to submit a support ticket. We're here to help! Thanks! 🙂
but i just want to know what the red light mean ??????
Hey there Pavelpouble,
Thank you so much for reaching out.
In regards to your Rift S, while it can occasionally flash an orange or yellow light, red is one of those colors that we would love to investigate further with you.
If you would please submit a support ticket complete with the log files of your computer so we can work toward a solution together.
To gather the logs:
    • The above link is the default directory. Bear in mind that if you installed Oculus Home to another drive you will need to update the command with the correct file path.
  7. Attach the newly created zip file to your support response.
We look forward to assisting you with this.
but **bleep** I may ask the question by email or on the forum you will never answer my questions are not?
nathanmnm
I had this problem just now, it turned out to be the cable plugged into the headset that was the issue - unplugged it and reseated it and it works ok now.
