03-01-2021 08:37 PM
PC Parts Below and Methods I Tried
I've had my Rift S ever since it first came out and so I preordered it off of Amazon. Once when I got it I had so many issues with the software where it just crashed every single time I opened it and I was so close to returning in the headset. Until one day I was able to fix it. After that, the headset was just working perfectly fine for about over 5 months or so... Until my headset started to flicker black every single time I moved my head. I dealt with it for like 2 weeks till I figured out it was my cable, so I bought a brand new replacement cable off of Oculus and it seemed like the cable was much thinner than the one that you get with the Rift S. But it was working completely fine. I also had an issue where if my controllers vibrate they would lose tracking like crazy. So I had to buy brand new ones and it started working perfectly fine by then. 8 months later, my headset started to crash like every 10 - 15 minutes. But as time went on it kept getting worse, like on some game it seemed it allowed me to play a little bit more on less demanding games. So I tried looking for fixes and to see if other people were able to solve this problem. After days of researching and troubleshooting. None of the fixes would work, until one day people I read a forum post saying that people were able to fix the problem by getting a powered USB hub. Then so I did and it worked I was so happy until a month later it started to occur again. So I bought another powered USB hub that cost like $30 and it still didn't fix the problem. Then I bought an Inateck PCI-E to USB 3.0 Express Card, when I went to try it, it just crashed straight away and it was legit worse than using the powered USB hub. Later on, with the issue, I was working on buying a new PC and just transferring the graphics card, 16 gigs of ram, and the same hard drives to the new PC. Once I got the pc all powered up and ready to go I went straight to playing on the Rift S and it still crashed no matter what I did including reusing the PCI Express card and the powered USB hub. Except I was able to get a little more time until it crashed. But at that point, I just gave up and I don't know what else to do. If I need to provide any more information just tell me because I really want this problem resolved.
Methods I've tried:
Old PC: HP Pavilion 690-0024 Prebuilt
RX 580 GPU
AMD Ryzen 5-2400G CPU
16 Gigs of DDR4 Ram
1 TB Hard Drive
2 TB Hard Drive
400 W PSU
For More Information About The PC: https://support.hp.com/in-en/document/c06124756
New PC:
MSI MPG Z390 Gaming Edge AC LGA1151 Motherboard
RX 580 GPU
Intel Core i7-9700K CPU
16 Gigs of DDR4 Ram
1 TB Hard Drive
2 TB Hard Drive
850 W 80+ Gold PSU
Motherboard Link: https://www.amazon.com/gp/product/B07HM3MD1D/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
Can't find the 850W CPU but here's the 750W version link: https://www.amazon.com/Power-Supply-Modular-Certified-Addressable/dp/B083RR7GBT/ref=sr_1_1?dchild=1&...
Inateck PCI-E to USB 3.0 PCI Express Card Link: https://www.amazon.com/Inateck-Express-15-Pin-Connector-KT5001/dp/B00FPIMJEW/ref=asc_df_B00FPIMJEW/?...
Can't find the first Powered USB Hub that I used but here's the second one: https://www.amazon.com/gp/product/B075NMVGP7/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
Solved! Go to Solution.
04-09-2021 11:20 AM
For the past week or so I bought a new cable and it's been working completely fine ever since. I have no idea why the problem was coming from the cable since it had no bends or anything and it looked completely fine to me. Right now I do have a small issue with the new cable though. Whenever I plug in the headset, most of the time it just doesn't detect that I have the USB plugged in. So I have to keep unplugging the USB and plugging it back in until it finally detects it. To be honest, it's not that big of a deal, I'm just happy that it works. I'll try to keep you guys up-to-date with anything that happens or any issues that appear.
04-07-2021 09:08 PM
This sounds like what I've been going through with my Rift S. Started about a year and a half ago. I have tried many of the same steps and I still get crashes. No BSOD, just a black screen, static noise, and the sound of my system rebooting. I haven't replaced any of the hardware but I did get a USB hub which seemed to fix it for a bit but the problem returned. I have a Ryzen 7 and an RX 580 on an ASRock B450 Pro4. For some reason the crashes only happen with Steam games. Titles from the Oculus store have never crashed my system.
04-08-2021 09:30 AM
In our post you don't mention what oculus version are you using. From v26 there are many user get crazy for oculus update,because have many device stop working.
i suggest to try downgrade your oculus, find how do thath in this topic: https://forums.oculusvr.com/t5/Oculus-Rift-S-and-Rift/Oculus-App-Update-issues/td-p/853014
is longer topic,but i suggest to read all of it.
04-08-2021 11:29 AM
I bought my Rift S about 3 weeks after the model was released. The problem started a year-and-a-half ago, so I have been experiencing it through a series of updates with versions from the first six months of the Rift S release. Quite a few versions. I am on the beta public test channel, though I'm not sure if that had anything to do with my issue or not. It *seems* be related to the Radeon software. I will take a look at the link and see if that helps, thank you.
04-09-2021 11:20 AM
11-15-2021 11:35 AM
where did you buy the new chord? was it oem? did you just buy it on amazon? im in your same funk man idk what to do...i packed it away with the intention of never using it again and buying the hp reverb instead but i broke down and im now trying to get this thing running again.
11-21-2021 11:41 AM
Yeah, that's been happening to me, except its been happening on all platforms. I've tried to do the same steps everyone says to do, yet nothing happened.
12-17-2021 10:03 AM
I was told i need to downgrade my CPU after i got a problem with my headset causing my pc to crash every time it is plugged in. I dont know what to do to fix it. The rift s worked fine one day the next day I got these issues out of no where
12-17-2021 10:22 AM
YOU PAID 200 DOLLARS FOR A CABLE?
we need to sue this company for breech of consumer contract. Discontinuing a hardware that supports the software we invested in... if you had a rift S you CANNOT USE A QUEST OR QUEST 2 TO PLAY YOUR TITLES. SO WHEN YOUR CABLE DIES LIKE MINE DID YOU WON'T BE ABLE TO GET ANYTHING OUT OF YOUR OCULUS ACCOUNTS.
12-17-2021 10:23 AM
RIDICULOUS NOBODY HAS BROUGHT THIS UP TO A LAWYER YET
