Since a while it's impossible for me to connect my Oculus Rift S, because of the USB 3.0 connection issue. I tried already so many troubleshootings and also the official oculus support couldn't help me so far. It seems to be a software problem with the oculus software or a conflict with a windows update. System specifications:
OS: Microsoft Windows 10 (10.0) Professional 64-bit (Build 19041)**
CPU: Intel(R) Core(TM) i5-9600K CPU @ 3.70GHz
GPU: NVIDIA GeForce RTX 2060
Mainboard: ASUSTeK ROG STRIX Z390-F GAMING
RAM: 16GB DDR4
Drive: SSD Samsung Evo 500GB
Oculus: 1.43.0.000018
Software: I'm a developer so I have installed dev tools like yarn, npm, docker, VM, ... maybe this a problem?
**Windows Version
Edition Windows 10 Pro
Version 20H2
Installed on 16.10.2020
build 19042.630
Windows Feature Experience Pack 120.2212.31.0
What I've tried already:
Followed Official Oculus Troubleshootings, e.g. this video: htt ps : / /w w w .you tube.com/watch?v=WYr6Q4GA5Wc
Unplugged and re-plugged USB and Displayport a couple of times. First the USB and after seeing a white light, connecting the Display Port. After a while the white light turns into a red light and the software tells me a usb connection problem. Or in setup the headset it will tell me after a while sensors can't track headset
Unplugged and re-plugged cable on the headset
Tried all USB ports (USB 2.0 connection works, but then it tells me, I have to use USB3.0)
Tried the headset on a different PC, which worked, so the cable is fine!
Installed newest graphic drivers and windows updates
Restarted the Oculus software and ended all the background services (Oculus Runtime, etc.)
Turned off USB power saving settings (Windows settings)
Deactivated Windows Gamemode (Windows Settings)
Deactivated all Windows Security (Real time protection, Cloud delivered protection, Windows Defender firewall, Automatic sample submission)
Disconnected all USB devices except mouse, keyboard, one monitor and rebooted windows
Uninstalled all Oculus applications and removed all folders*
Reinstalled newest oculus software
Registered to Oculus public test channel (oculus/settings/beta)
Used a brand new internal PCIe USB 3.1 Superspeed Card (10Gbps) (Inateck, ASMedia)
Tried external USB 3.0 Hub with own power connection
Sent my pc specifications and oculus logs by using OculusLogGatherer to official oculus support: htt p s : / /s upport. o culus.c om/172672339980954/
FYI - when I forced an update to ASMedia extensible host 3.1 driver using the latest from the Microsoft website, it cleared out all driver issues and now my Oculus connects. Hope this thread helps someone else. Frustrating that Windows says the driver is up to date, but Microsoft has a newer driver that solves this issue. You have to force the update with "have disk" too.
Nice, thanks for this. Anyway, I actually have to reconnect the oculus everytime after restart my PC but than it worked fine. It seems like the latest oculus update fixed also some problems.
Get Help
