Rift S and Rift 1.40 PTC Release Notes
Oculus Community Manager
Guardian
We’ve made performance improvements and feature updates to improve your experience while interacting with Guardian. These updates include:
  • Ability to clear your Guardian boundary history from your Guardian settings menu.
  • Opportunity to confirm your Guardian boundaries are accurate when you first put on your headset.
  • Removed the need to indicate what direction is forward when setting up Guardian.
Store
  • Updated the design, and improved performance and load times for the Oculus Store.
Home
  • You can now collect all of your Oculus Home rewards at once with the new Collect All button.
Fixes
  • Fixed an issue where touch controllers could lose tracking during fast movements with Rift.
  • Removed warning that USB drivers needed to be updated when drivers were already up to date.
As always, if you encounter any issues with this software release, please be sure to report them using the Help Center > Provide Feedback option within the Oculus desktop software. If you have any feature requests or suggestions to make the Oculus software even better, please head over to our UserVoice page to share your feedback. Thanks for your continued help!
143 REPLIES 143
Digikid1
Level 12
Home
Fixes
Well.....it took you long enough for the COLLECT ALL feature....
As for the USB fix....a LOT of ppl will be VERY happy about that.
Error-401
Downloading as we speak :smiley: yay to the USB fix
PC: Intel Core i9-9900K | Corsair Vengeance DDR4 3200 16GB | MSI RTX 2080 Ventus | Samsung 970 Pro NVMe | SilverStone SX700-LPT | GIGABYTE Z390 I AORUS PRO WiFi | SilverStone RVZ03B-ARGB
dburne
Level 16
Sounds great Oculus, now I can collect all my rewards and I am sure I have plenty backed up.
Also nice to have all my devices showing green again.
Just checked the store, sooo much better thanks!
Nice to see you listening to the community!
Rift CV1| Rift S| Quest| Reverb G2| Index
dburne
Level 16
I am getting a message " Something went wrong and your  device can not track the movement of the headset".
However tracking seems fine, so not sure why I am getting that message.
It pops up in the headset when I put it on, and remains in the Notification area.
JimO22
I am getting the same message " Something went wrong and your  device can not track the movement of the headset".
ShowbizDonkey
Thanks for reporting. This is a known issue that we're working on resolving asap. It should not affect functionality. I'll see if we can get the release notes updated to call this out.
john.zigmont
Level 6
Same here "Something went wrong and your  device can not track the movement of the headset".
dburne
Level 16
Great, thanks for the quick feedback!
kojack
Volunteer Moderator
Volunteer Moderator
Yay for my Rift-S now getting a green tick (no more orange due to false usb update warning).
