Rift S working on my bros pc but not on mine
vlad_kalinsky
Hello,
i know there are a lot of posts of this issue but none of the suggestions there helped. so i hopelessly scream for help at this point.
i have my oculus for about 1.5 years now (not sure exactly). and been playing on it on my previous PC for the first year or so with no major technical issues
these were my PC specs:
i5 6400
16 GB RAM
GTX 1070 8GB
and then it started
i then upgraded my pc, CPU, RAM, MOBO and cooling... but stayed with the 1070 for the GPU
so this was is then
Ryzen 5 5600x
16 GB 3600 mhz
B550M DS3H rev.1
i think this was the phase i started to get crashes after playing 5-15 mins but im not sure
i wasn't really making track of this at this time
then i upgraded my GPU to 3070ti (*hehe boi...*and with this last upgrade all my old PC goes to my Bro)
the prob. with the 5-15 mins crash proceeded...
and then at some point it completely stopped working, by that i mean:
i open oculus then put the headset on
i then see the guardian setup window pop up in front
then move to the next window to set ground level (at this point im at 5-10 secs after im in VR)
i bend to get the controller to touch the ground, the the tracking stops i see all my surroundings as grey noise
with the guardian window stays till the lens go black and the orange light pop on the headset.
on the oculus app it says the D-port isnt recognized or its disconnecting all the time.
BUT!
when i plug the Rift S to my older pc that my bro has now
i can play freely on the google VR app and all works fine
thing we've tried on my new PC with my bro:
reinstall oculus
buy and install a PCIe UBS 3.0 (with no external power supply) extension on the mobo, plug the rift s usb to it (with no success)
format the pc
5 REPLIES 5
Greetings, Vlad_kalinsky! We can definitely see why this may be concerning. We appreciate you providing us with such scripted details.
It seems like there's a connection issue that's causing the games to crash. At this point, we would like you to collect your logs and submit a support ticket.
You can use the steps below to gather your logs:
    • The above link is the default directory. Bear in mind that if you installed the Oculus PC app to another drive you will need to update the command with the correct file path.
Once you collect this information, one of our specialists can take a deeper look into the exact error that's causing your games to crash. Thank you for reaching out!
i cant add zip it says its not supported and then i extracted it but still it wont let me add it here
Thank you for getting back to us! You won't be able to add the file here. You'll need to submit a support ticket and send the file to one of our specialists so they can take a deeper look!
vlad_kalinsky
this what i get when i go to this like and log it to submit a ticket...
Thanks for providing us with that screenshot, are you able to open up a chat on our support page
