06-26-2018 02:01 PM
06-29-2018 03:38 PM
cybereality said:
June 29th Update:
We're rolling out some new features in the current Rift SI version 1.28 Public Test Channel release, including our first step towards multiplayer functionality in Home!
- Rift Core 2.0 Beta
- We've added experimental support for broadcasting your Oculus Desktop in multiplayer using the new Dash panel embedding feature. There are some technical limitations, which you can read about in the Rift Core 2.0 beta user guide.
cybereality said:
June 29th Update:
- New movement options are now available in Home. Check out your settings menu for a new “Movement” section where you can set up various options for moving around, including Walk Mode, Smooth Turning, and Snap Turning. While some of the new movement options like Walk Mode and Smooth Turning allow for direct control, they may not be comfortable for everyone.
06-30-2018 03:35 PM
06-30-2018 04:35 PM
07-01-2018 02:17 AM
I'm out of VR. Well, not really, but that would still suck xD!
07-01-2018 03:23 AM
07-01-2018 03:47 AM
07-01-2018 06:19 AM
07-01-2018 06:36 AM
Monstaah said:
I'm gonna be a lone voice and stand up and say, I actually prefer the new skin tones option vs the old colourful ones!!. but yeah I do miss my hat (and the hairstyle that came with it) and the shades I had as well, look forward to their return..
07-01-2018 09:00 AM
07-01-2018 09:16 AM
TickTock said:
OK. So how do I get the "click here to invite friends to your home" (or something like that) balloon to go away. It is stuck on my wrist and won't go away (been through multiple power cycles, and clicked through all the menus).
