I bought it second hand and every thing else except from some little scratches on the outside was perfect. Right speaker's screw came loose,upon closer inspection the little plastic silinder that the screw is supposed to be screwed in has shatterd.Right now i have tried glueing it with a very small amount of glue which worked but it isnt gripped as hard as the other speaker.My father suggested we remove the broken silinder and place a small piece of molten plastic so the screw can be pushed into it and create a something that looked kind of like the old piece.If that doesnt work i was thinging that i could find the whole arm that holds the speaker and replace it.
