07-06-2020 07:23 AM
07-07-2020 07:51 AM
07-07-2020 04:13 PM
Ash4ord said:
Update
I finally found the problem!
I installed a StarTech.com 4 Port PCI Express USB 3.0 Card (PEXUSB3S2EI) it came with its own drivers which i installed and was getting the sensor check error, I deleted the drivers that it came with and let windows install its own generic drivers and it passed the sensor check within seconds and is now working fine and auto connecting after restarts etc.
I felt it was only right to update this thread rather than abandon it after finding a solution, I was convinced the problem was with the rift and turns out it was the drivers, technically you could argue that the rift is fussy about usb drivers so technically its still partly at fault as all my other devices worked with the other drivers. That said its now working fine so anybody who may read this in the future can see a solution as i have come across a lot of other threads around the internet with the same problem and you don't always see a reply when a solution is found and this can leave a impression of the rift.
07-07-2020 04:28 PM
