[SOLVED] USB not detected
The2ndDemo
My rift worked one night then today I turn on my computer and my oculus rift isn't detecting USB connection or HDMI. It's plugged into USB 3 and the power management settings are disabled so the ports shouldn't be turned off. I've tried different ports but nothing seems to be changing. I've also reinstalled drivers so I am at a loss for what to do
The2ndDemo
I took off the plastic cover around the edge and physically plugged and unplugged the port from the headset to fix it
