Screenshot using oculus mirror
HammerPiano
Hi there,
Before I updated oculus software to the lastest version, I used the oculus mirror program to take screenshots while playing vr games.
I could use it to take screen shots in full HD, and even in 4k which is awesome.
After the update, I can no longer do it, I have to open the program and then only using the program I can take a screenshot, and even then the resolution is very bugged out.
I used this command:
OculusMirror.exe --Screenshot <image_path> --Size 1920 1080
To take the screen shot, and it worked until the latest update.
What can I do to fix this?
0 REPLIES 0
