SDE is a constant - meaning it's a physical limitation to the Rift hardware. Ss doesn't change the SDE, but does increase your depth perception and image quality. If you move your head less than usually you may notice the SDE more. Some colors like blue and white seem to limit SDE, while red and orange may be the worst. And if you look for the SDE you will notice it much more than if you don't and just focus on the game. Thus there may be multiple reasons for you to notice the SDE more than usually...
