There are three items to fix. VRC.PC.Functional.3 VRC.PC.Input.1 VRC.PC.Input.2
kogene
Honored Guest
I'm having trouble with Test Results.
Because, the "pause" of the modification is stopped on the screen.
And it's just like playing any other game.
(Although some apps are not stopped)
However, my game has feedback to fix.
Maybe
I may be wrong in the meaning of "pause" to fix.
I'm in great trouble because I don't know how to fix it.
VRC.PC.Functional.3
VRC.PC.Input.1
VRC.PC.Input.2
Does anyone know how to clear these three fixes?
Thank you very much.
3 REPLIES 3
Sheepgamer2000
Protege
VRC.PC.Functional.3 is a program in which pauses the game you're playing (singleplayer) when opening the oculus menu or removing your VR-headset from your head and is not required when playing multiplayer games. you can test is via starting singleplayer games and then remove your VR-headset.
VRC.PC.Input.1 IS required, im not sure how to fix it, you should check for other posts or look around on youtube.
VRC.PC.Input.2 it's similar to the VRC.PC.Functional.3 but only connected to the Oculus Dash if you want to fix this try testing it the same way as you did with the other. This is also required to have for your device.
This is mostly info, not a solution, but I hope it helps you better understand what to do.
these are also just tests which you can use for yourself. you should download the correct test plan for your device here:link
would recommend the .csv because you can never be to safe with .xls files.
Get Help
Check out some popular posts here:
Getting Help from the Meta Quest Community
Tips and Tricks: Charging your Meta Quest Headset
Tips and Tricks: Help with Pairing your Meta Quest
Trouble With Facebook/Instagram Accounts?
