05-06-2020 03:41 PM
Solved! Go to Solution.
05-16-2020 02:29 PM
05-16-2020 04:07 PM
05-16-2020 04:33 PM
1960Steve said:
How do I tell which version of Oculus it is?
05-17-2020 12:53 AM
05-18-2020 10:55 AM
05-18-2020 02:05 PM
05-19-2020 12:00 AM
Oculus v17 rolled out to me today. All seems to work fine. During the installation I did not see any new driver install windows. After it finished installing I shutdown my PC (full, not sleep or hibernate btw). Then restarted my pc and fired up my Oculus Rift cv1 w/2x sensors.
I tried a couple Oculus Store games (including Lone Echo for ~30 minutes), a couple Steam games, and a couple VivePort games. Everything ran good as ever, no problems. Also, all my Oculus devices properly reported usb 3.0 in the green.
Although I don't really use my Rift for xp11 anymore, just my Vive Pro, I thought I'd give it a go anyway. I always startup xp11 with my Rift by calling up the Oculus desktop panel, then use my mouse to startup with a shortcut on my taskbar. 11.50b9 Vulkan started up no problems and I ended up in the usual startup hangar facing the menu boards. Selected a flight and all worked perfectly. Had a good fly around Chicago at dawn and everything was a very smooth 45-55fps. The good old Oculus shutdown bug is still in effect and I still need to use task manager to kill it.
So, for me, v17 is working fine. Thank goodness!
ASIDE: In the past I have occasionally had xp11 hang either during the wait to get to the hangar and/or when I tried to start a new flight. In all these cases this was due to using too high xp11 and/or super sampling settings. Once I lowered these (xp11 by starting up in 2D monitor mode), SS for me with OTT, all worked fine. For those having issues starting up xp11 in VR you might want to consider this. Good luck mates and cheers.
05-19-2020 04:25 AM
05-19-2020 07:51 AM
05-19-2020 08:50 AM
