Vibration on controllers causes extreme game lag
Zombiepuppy
i wish there was a way to turn off controller vibration all together.
iMight404
Oculus Support
Oculus Support
That's so odd that vibration on controllers is causing lag for you. I believe there's an option in the oculus app to accomplish this, but only if you have dev mode enabled. If you do, you should be able to go to tracking and controller, scroll all the way down and there should be an option to adjust vibration level.
Take your destiny into your own hands. Sand cannot keep a shape by itself, but add water and it becomes malleable. Fate can be such, if you add the right element.
