โ05-27-2019 07:39 AM
โ05-27-2019 08:44 AM
โ05-27-2019 10:07 AM
โ05-27-2019 08:22 PM
OculusSupport said:
Hey @misfitpunish3r, I'm sorry to hear you're having experiencing static on your Rift S. If you're noticing static on the headset, please try disconnecting your Rift S, wait 10 seconds, connect your USB, wait another 10 seconds then connect your DisplayPort connection. It's important to allow the USB connection to fully establish before connecting the DP port. Also, please try reseating the cable on the headset side. You'll need to remove the facial interface first to access it. Please contact support at https://support.oculus.com if you're still having issues. Thanks! -Rick
โ05-27-2019 08:34 PM
โ05-28-2019 03:30 AM
โ05-28-2019 10:59 AM
โ05-28-2019 11:30 AM
โ05-28-2019 11:31 AM
I could not help but notice, you have posted in every different issue thread that you have the same problem and you have returned the garbage.
antitrust42 said:
same problem here i return this garbage
