08-14-2019 04:57 AM
08-14-2019 11:38 AM
08-14-2019 01:44 PM
08-15-2019 07:50 AM
MohWarfighter said:
It just suddenly did not work, and don't know what to do. I have tried everything that the oculus support sites have said and tried all kinds of different ports and stuff. When i connect the displayport cable it works in a brief moment before it disconnects. This makes me believe it has something to do with the USB not giving enough power to the displayport (?). A thing that strengthens this is a error from the log which is seen many times:
"USB connection failed via pc_hal_sensor_data_read"
Has anyone had the same problem, or knows how to fix this?
08-16-2019 03:55 AM
08-16-2019 05:45 PM
08-31-2019 07:48 PM
08-31-2019 07:50 PM
09-03-2019 07:28 PM
09-04-2019 08:59 AM
bigcat1969 said:
This shit hasn't been sorted in months and is getting worse and worse with every update for me. It just took 4 attempts to watch a couple minute video. The web is crawling with reports about the problems. Why shouldn't we want to go elsewhere. The idea is that the Rift S is a mature product when in fact it is a failure for a huge number of people. You want to kill PC VR, turn it into an eternal beta test. Your TV works when you turn it on, your console works when you turn it on, your phone works when you turn it on, your $400 VR headset should work when you turn it on, not require 4 attempts.
