rift s plugin cable :/
F1SHISCOOL
So basically... My pet kitten broke the wire on my vr headset, Anywhere to buy a replacement cable??? Because I don't wanna buy an entire new headset which is pretty pricey. Just looking for a plugin cable....
Bye.
killerclays
if you have a home insurace, you could try to ask them for that. Dont know how that works in your country. But you can always try
kojack
Volunteer Moderator
Volunteer Moderator
The cable is available from here: https://www.oculus.com/rift-s/accessories/
Except at the moment USA and Canada are out of stock. The rest of the world has it though (might need an overseas friend/family to buy one for you).
