tried fixing Rift S Controller joy stick drift and now right one dosen't work
ThiccMan
like what the title says, i have really bad joystick drift so i watched a video about taking out the batteries for 3 minutes and blowing air into the exposed holes to fix it but only the left controller works now with the same joystick drift as before and the right one dosen't power on anymore ( the white light is gone and oculus says that the controller is disconnected ).
is there anything that can be done about this? ( btw i will try anything except buying a new controller for this headset since it dosen't work well anyway with all the crashes with the high pitched constant beep and then static with the screen going black and then me getting a displayport connection lost error on my pc, even the speakers seem to be dying with any loud sound getting bit crushed. )
0 REPLIES 0
