Application updated to SDK0.7 submited and approved, but...
viewport
Hello,
Our application has been updated to SDK 0.7 and is approved by Oculus Share. However still shows "pre-0.6.0"
Application name: Viewport Point-to-Point Experience
Version: 1.1
Submitted Date: Thu Jul 30 2015 13:46:24 GMT+0000 (UTC)
Thank you Very much.
13 REPLIES 13
cybereality
Level 15
Which SDK or integration did you use?
viewport
Oculus Utilities for Unity 5 V0.1.0-beta and Unity 5.1.2p2
Already tested in SDK 0.7 / Windows 10 and working smoothly.
Thank you.
kevingulling
No option during submission for post-0.6 applications. (Or for that matter pre 0.6, it automatically calls it pre-0.6)
Come on guys... This is so lazy that you make me look good. :lol:
cybereality
Level 15
I'm checking on this for you guys. It's possible there is a bug.
viewport
Thank you Cyber, happy to help somehow if there is a bug from any side.
cybereality
Level 15
Looks like there was a bug, but I've been told it was fixed.
You can try resubmitting the game with the same zip file and it should correct itself.
viewport
Thank you Cyber, Ill do it right now.
viewport
Files has been resubmited again. I Hope it fixes the issue soon.
Thank you.
viewport
Application has been resubmited and approved twice and still shows PRE 0.6.
Could you please change the status manually? Thank you.
Version: 1.1
Bt the way I would really apretiate your help through this way, since I have wrote 3 emails to Oculus Developer Suppot whitin 2 months and nothing really happened.
