11-15-2014 09:39 PM
void ShutdownVR()
#ifdef HAVE_OCULUSSDK
if (hmd)
// on my computer, on runtime 0.4.2, the Rift won't switch itself off without this:
if (!(hmd->HmdCaps & ovrHmdCap_ExtendDesktop))
ovrHmd_SetEnabledCaps(hmd, ovrHmdCap_DisplayOff);
ovrHmd_Destroy(hmd);
g_has_rift = false;
g_has_hmd = false;
NOTICE_LOG(VR, "Oculus Rift shut down.");
ovr_Shutdown();
#endif
11-15-2014 09:53 PM
"2EyeGuy" wrote:
In Direct Mode, when I run a DK2 application (except Dolphin VR), and exit that application, the DK2 always stays switched on, with the blue light on and the image locked on the screen. Pressing the DK2 power button to turn off the DK2 and then turning it back on again, makes it go straight back to the blue light being on and the image locked to the screen. The only way to fix it is to change to extended mode, then change back to direct mode, OR run Dolphin VR. The problem exists in the desk demo, Oculus World Demo, and Oculus Tiny Room, Dolphin VR before I fixed it, and presumably other demos.
As you can imagine, that is a huge problem as it will quickly burn that image into the screen.
This issue has been present at least since 0.4.2, and probably earlier, but I didn't really use Direct Mode before then because I couldn't get it to work in my OpenGL code.
In the Github version of Dolphin VR, I fixed that issue with this code:void ShutdownVR()
if (hmd)
g_has_rift = false;
g_has_hmd = false;
ovr_Shutdown();
#endif
11-15-2014 10:35 PM
System Information
Time of this report: 11/16/2014, 16:49:31
Machine name: CARL3D
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.140706-1506)
Language: English (Regional Setting: English)
System Manufacturer: TOSHIBA
System Model: Satellite P750
BIOS: BIOS Date: 12/15/11 11:42:39 Ver: AMI APTIO 2.40
Processor: Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz (8 CPUs), ~2.0GHz
Memory: 8192MB RAM
Available OS Memory: 8170MB RAM
Page File: 3959MB used, 12378MB available
Windows Dir: C:\windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: The file WsAudio_DeviceS(3).sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 3: The file WsAudio_DeviceS(2).sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 4: The file WsAudio_DeviceS(5).sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 5: The file WsAudio_DeviceS(1).sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 6: The file WsAudio_DeviceS(4).sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GT 540M
Manufacturer: NVIDIA
Chip type: GeForce GT 540M
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0DF4&SUBSYS_FC351179&REV_A1
Display Memory: 4049 MB
Dedicated Memory: 977 MB
Shared Memory: 3071 MB
Current Mode: 1360 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: CMO1598
Native Mode: 1366 x 768(p) (119.997Hz)
Output Type: Internal
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 9.18.0013.3788 (English)
Driver Version: 9.18.13.3788
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 5/20/2014 13:14:03, 17480432 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-4EB4-11CF-057C-38DC1CC2C435}
Vendor ID: 0x10DE
Device ID: 0x0DF4
SubSys ID: 0xFC351179
Revision ID: 0x00A1
Driver Strong Name: oem8.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section109:9.18.13.3788:pci\ven_10de&dev_0df4&subsys_fc351179
Rank Of Driver: 00E00001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0269&SUBSYS_1179FC36&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.6305 (English)
WHQL Logo'd: Yes
Date and Size: 2/10/2011 12:40:04, 2738536 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Speakers (WsAudio_DeviceS(3))
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: WsAudio_DeviceS(3)
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: WsAudio_DeviceS(3).sys
Driver Version: 1.00.0000.0001 (English)
WHQL Logo'd: No
Date and Size: 12/24/2010 15:27:44, 29288 bytes
Other Files:
Driver Provider: WsAudio_DeviceS(3)
Cap Flags: 0xF1F
HW Memory: 0
Description: Speakers (WsAudio_DeviceS(2))
Hardware ID: WsAudio_DeviceS(2)
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: WsAudio_DeviceS(2).sys
WHQL Logo'd: No
Other Files:
Driver Provider: WsAudio_DeviceS(2)
Cap Flags: 0xF1F
HW Memory: 0
Description: Speakers (WsAudio_DeviceS(5))
Hardware ID: WsAudio_DeviceS(5)
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: WsAudio_DeviceS(5).sys
WHQL Logo'd: No
Other Files:
Driver Provider: WsAudio_DeviceS(5)
Cap Flags: 0xF1F
HW Memory: 0
Description: Speakers (WsAudio_DeviceS(1))
Hardware ID: WsAudio_DeviceS(1)
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: WsAudio_DeviceS(1).sys
WHQL Logo'd: No
Other Files:
Driver Provider: WsAudio_DeviceS(1)
Cap Flags: 0xF1F
HW Memory: 0
Description: Speakers (WsAudio_DeviceS(4))
Hardware ID: WsAudio_DeviceS(4)
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: WsAudio_DeviceS(4).sys
WHQL Logo'd: No
Other Files:
Driver Provider: WsAudio_DeviceS(4)
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (Realtek High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Line (WsAudio_DeviceS(5))
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x1
Description: Line (WsAudio_DeviceS(4))
Cap Flags: 0x1
Description: Line (WsAudio_DeviceS(1))
Cap Flags: 0x1
Description: Line (WsAudio_DeviceS(2))
Cap Flags: 0x1
Description: Line (WsAudio_DeviceS(3))
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: ENE CIR HID Receiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1524, 0x0100
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Microsoft eHome Infrared Transceiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x006D
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Bluetooth HID Port
Attached: 1
Controller ID: 0x1
Vendor/Product ID: 0x057E, 0x0306
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x2
FF Driver: n/a
Attached: 1
Controller ID: 0x4
FF Driver: n/a
Attached: 1
Controller ID: 0x5
FF Driver: n/a
Device Name: vmultia HID
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x001F, 0xBA1C
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x3
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x1C26
| Matching Device ID: usb\root_hub20
| Service: usbhub
| Driver: usbhub.sys, 11/27/2013 12:11:37, 343040 bytes
| Driver: usbd.sys, 11/27/2013 12:11:03, 7808 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0024
| | Matching Device ID: usb\class_09
| | Service: usbhub
| +-+ Generic USB Hub
| | | Vendor/Product ID: 0x05E3, 0x0608
| | | Service: usbhub
| | +-+ USB Input Device
| | | | Vendor/Product ID: 0x046D, 0xC50E
| | | | Matching Device ID: generic_hid_device
| | | | Service: HidUsb
| | | | Driver: hidusb.sys, 11/21/2010 13:53:47, 30208 bytes
| | | | Driver: hidclass.sys, 7/3/2013 14:35:05, 76800 bytes
| | | | Driver: hidparse.sys, 7/3/2013 14:35:04, 32896 bytes
| | | +-+ HID-compliant mouse
| | | | | Matching Device ID: hid_device_system_mouse
| | | | | Service: mouhid
| | | | | Driver: mouhid.sys, 7/14/2009 10:30:20, 31232 bytes
| | | | | Driver: mouclass.sys, 7/14/2009 12:18:27, 49216 bytes
| +-+ Generic USB Hub
| | | Vendor/Product ID: 0x2833, 0x2021
| | | Service: usbhub
| | | | Vendor/Product ID: 0x2833, 0x0021
| | | | Service: HidUsb
| | | +-+ HID-compliant device
Gameport Devices
PS/2 Devices
+ Standard PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 7/14/2009 09:49:57, 105472 bytes
| Driver: kbdclass.sys, 7/14/2009 12:18:04, 50768 bytes
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 11/21/2010 13:53:47, 33280 bytes
+ Microsoft eHome Remote Control Keyboard keys
| Matching Device ID: hid\irdevicev2&col05
| Service: kbdhid
+ Microsoft eHome MCIR Keyboard
| Matching Device ID: hid\irdevicev2&col06
| Service: kbdhid
+ Microsoft eHome MCIR 109 Keyboard
| Matching Device ID: hid\irdevicev2&col07
| Service: kbdhid
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ Synaptics PS/2 Port TouchPad
| Matching Device ID: *tos0300
| Upper Filters: SynTP
| Service: i8042prt
| Service: mouhid
| Service: mouhid
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 11/21/2010 13:53:47, 63360 bytes
| Driver: sermouse.sys, 7/14/2009 10:30:20, 26624 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 3.5 GB
Total Space: 702.3 GB
File System: NTFS
Model: TOSHIBA MK7575GSX (TurboPC)
Drive: Q:
Model: n/a
Drive: T:
Free Space: 2613.7 GB
Total Space: 3815.4 GB
File System: NTFS
Model: Seagate Backup+ Desk USB Device
Drive: 😧
Model: HL-DT-ST BD-RE BT11F
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), 11/21/2010 13:53:47, 147456 bytes
Drive: E:
Model: MagicISO Virtual DVD-ROM0000
System Devices
Name: LPC Interface Controller
Device ID: PCI\VEN_8086&DEV_1C49&SUBSYS_FC301179&REV_04\3&11583659&1&F8
Driver: C:\windows\system32\DRIVERS\LPCFilter.sys, 1.00.0064.0005 (English), 3/23/2010 04:25:20, 46192 bytes
Driver: C:\windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 12:18:27, 15424 bytes
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 2 - 1C12
Device ID: PCI\VEN_8086&DEV_1C12&SUBSYS_FC301179&REV_B4\3&11583659&1&E1
Driver: C:\windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/21/2010 13:53:47, 184704 bytes
Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_1C3A&SUBSYS_FC301179&REV_04\3&11583659&1&B0
Driver: n/a
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 1 - 1C10
Device ID: PCI\VEN_8086&DEV_1C10&SUBSYS_FC301179&REV_B4\3&11583659&1&E0
Name: Atheros AR9002WB-1NG Wireless Network Adapter
Device ID: PCI\VEN_168C&DEV_002B&SUBSYS_661311AD&REV_01\4&2F3C7C28&0&00E1
Driver: n/a
Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
Device ID: PCI\VEN_8086&DEV_1C2D&SUBSYS_FC301179&REV_04\3&11583659&1&D0
Driver: C:\windows\system32\drivers\usbehci.sys, 6.01.7601.18328 (English), 11/27/2013 12:11:11, 53248 bytes
Driver: C:\windows\system32\drivers\usbport.sys, 6.01.7601.18328 (English), 11/27/2013 12:11:11, 325120 bytes
Driver: C:\windows\system32\drivers\usbhub.sys, 6.01.7601.18328 (English), 11/27/2013 12:11:37, 343040 bytes
Name: Intel(R) Mobile Express Chipset SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_1C03&SUBSYS_FC301179&REV_04\3&11583659&1&FA
Driver: C:\windows\system32\DRIVERS\iaStor.sys, 10.01.0002.1004 (English), 1/13/2011 11:21:44, 439320 bytes
Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_FC301179&REV_06\4&1FA51BC8&0&00E0
Driver: n/a
Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26
Device ID: PCI\VEN_8086&DEV_1C26&SUBSYS_FC301179&REV_04\3&11583659&1&E8
Name: 2nd generation Intel® Core™ processor family DRAM Controller - 0104
Device ID: PCI\VEN_8086&DEV_0104&SUBSYS_FC301179&REV_09\3&11583659&1&00
Driver: n/a
Name: NVIDIA GeForce GT 540M
Device ID: PCI\VEN_10DE&DEV_0DF4&SUBSYS_FC351179&REV_A1\4&332D2A89&0&0008
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 9.18.0013.3788 (English), 5/20/2014 13:14:03, 440152 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 5/20/2014 13:14:03, 1183672 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvtdi.inf_amd64_neutral_e003aaaba0cbb667\NvCplSetupInt.exe, 1.00.0001.0000 (English), 5/20/2014 13:14:03, 82894768 bytes
Driver: C:\Program Files\NVIDIA Corporation\license.txt, 5/20/2014 13:14:03, 21898 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\MCU.exe, 1.01.5204.20580 (English), 5/20/2014 13:14:03, 843720 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvdebugdump.exe, 6.14.0013.3788 (English), 5/20/2014 13:14:03, 224032 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.1.pdf, 5/20/2014 13:14:03, 50585 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 8.17.0013.3788 (English), 5/20/2014 13:14:03, 329672 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvml.dll, 8.17.0013.3788 (English), 5/20/2014 13:14:03, 543520 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 1.00.0000.0000 (English), 5/20/2014 13:14:03, 52056 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll, 1.00.0000.0000 (English), 5/20/2014 13:14:03, 61216 bytes
Driver: C:\windows\system32\DRIVERS\nvlddmkm.sys, 9.18.0013.3788 (English), 5/20/2014 13:14:03, 12688328 bytes
Driver: C:\windows\system32\NvFBC64.dll, 6.14.0013.3788 (English), 5/20/2014 13:14:03, 892704 bytes
Driver: C:\windows\system32\NvIFR64.dll, 6.14.0013.3788 (English), 5/20/2014 13:14:03, 895776 bytes
Driver: C:\windows\system32\nvapi64.dll, 9.18.0013.3788 (English), 5/20/2014 13:14:03, 3109248 bytes
Driver: C:\windows\system32\nvcompiler.dll, 8.17.0013.3788 (English), 5/20/2014 13:14:03, 25256224 bytes
Driver: C:\windows\system32\nvcuda.dll, 8.17.0013.3788 (English), 5/20/2014 13:14:03, 11644928 bytes
Driver: C:\windows\system32\nvcuvenc.dll, 8.17.0013.3788 (English), 5/20/2014 13:14:03, 2785568 bytes
Driver: C:\windows\system32\nvcuvid.dll, 8.17.0013.3788 (English), 5/20/2014 13:14:03, 3141976 bytes
Driver: C:\windows\system32\nvd3dumx.dll, 9.18.0013.3788 (English), 5/20/2014 13:14:03, 17480432 bytes
Driver: C:\windows\system32\nvinfo.pb, 5/20/2014 13:14:03, 26069 bytes
Driver: C:\windows\system32\nvoglv64.dll, 9.18.0013.3788 (English), 5/20/2014 13:14:03, 31387936 bytes
Driver: C:\windows\system32\nvopencl.dll, 8.17.0013.3788 (English), 5/20/2014 13:14:03, 11599072 bytes
Driver: C:\windows\system32\nvwgf2umx.dll, 9.18.0013.3788 (English), 5/20/2014 13:14:03, 18531568 bytes
Driver: C:\windows\SysWow64\NvFBC.dll, 6.14.0013.3788 (English), 5/20/2014 13:14:03, 861128 bytes
Driver: C:\windows\SysWow64\NvIFR.dll, 6.14.0013.3788 (English), 5/20/2014 13:14:03, 867784 bytes
Driver: C:\windows\SysWow64\nvapi.dll, 9.18.0013.3788 (English), 5/20/2014 13:14:03, 2730208 bytes
Driver: C:\windows\SysWow64\nvcompiler.dll, 8.17.0013.3788 (English), 5/20/2014 13:14:03, 17561544 bytes
Driver: C:\windows\SysWow64\nvcuda.dll, 8.17.0013.3788 (English), 5/20/2014 13:14:03, 9735256 bytes
Driver: C:\windows\SysWow64\nvcuvenc.dll, 8.17.0013.3788 (English), 5/20/2014 13:14:03, 2412376 bytes
Driver: C:\windows\SysWow64\nvcuvid.dll, 8.17.0013.3788 (English), 5/20/2014 13:14:03, 2953672 bytes
Driver: C:\windows\SysWow64\nvd3dum.dll, 9.18.0013.3788 (English), 5/20/2014 13:14:03, 14434704 bytes
Driver: C:\windows\SysWow64\nvoglv32.dll, 9.18.0013.3788 (English), 5/20/2014 13:14:03, 24025376 bytes
Driver: C:\windows\SysWow64\nvopencl.dll, 8.17.0013.3788 (English), 5/20/2014 13:14:03, 9697640 bytes
Driver: C:\windows\SysWow64\nvwgf2um.dll, 9.18.0013.3788 (English), 5/20/2014 13:14:03, 16003912 bytes
Driver: C:\windows\system32\nvdispco6433788.dll, 2.00.0040.0004 (English), 5/20/2014 13:14:03, 1889112 bytes
Driver: C:\windows\system32\nvdispgenco6433788.dll, 2.00.0019.0002 (English), 5/20/2014 13:14:03, 1541576 bytes
Name: Intel(R) 6 Series/C200 Series Chipset Family SMBus Controller - 1C22
Device ID: PCI\VEN_8086&DEV_1C22&SUBSYS_FC301179&REV_04\3&11583659&1&FB
Driver: n/a
Name: 2nd generation Intel® Core™ processor family PCI Express Controller - 0101
Device ID: PCI\VEN_8086&DEV_0101&SUBSYS_FC301179&REV_09\3&11583659&1&08
Name: High Definition Audio Controller
Device ID: PCI\VEN_10DE&DEV_0BEA&SUBSYS_FC351179&REV_A1\4&332D2A89&0&0108
Driver: C:\windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/21/2010 13:53:47, 122368 bytes
Device ID: PCI\VEN_8086&DEV_1C20&SUBSYS_FC301179&REV_04\3&11583659&1&D8
Name: Renesas Electronics USB 3.0 Host Controller
Device ID: PCI\VEN_1033&DEV_0194&SUBSYS_FC301179&REV_04\4&22BA660E&0&00E5
Driver: C:\windows\system32\DRIVERS\nusb3xhc.sys, 2.00.0034.0000 (English), 2/11/2011 08:22:34, 181760 bytes
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 6 - 1C1A
Device ID: PCI\VEN_8086&DEV_1C1A&SUBSYS_FC301179&REV_B4\3&11583659&1&E5
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 4 - 1C16
Device ID: PCI\VEN_8086&DEV_1C16&SUBSYS_FC301179&REV_B4\3&11583659&1&E3
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
Zune AAC Decoder DMO,0x005fffff,1,1,ZuneAACDec.dll,11.05.7600.6740
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.18221
Microsoft Zune Mpeg4s Decoder DMO,0x00800001,1,1,ZUNEMP4SDECD.dll,12.08.2345.0000
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.02.0000.0000
ffdshow DXVA Video Decoder,0xff800002,2,1,ffdshow.ax,1.02.0000.0000
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.02.0000.0000
ffdshow Audio Decoder,0xff800001,1,1,ffdshow.ax,1.02.0000.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.18526
LAV Splitter,0x00800004,1,1,LAVSplitter.ax,0.53.0002.0000
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Zune Enhanced Video Renderer,0x00200000,1,0,ZuneEvr.dll,4.08.2345.0000
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.18526
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.18526
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.9200.17037
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.18526
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.18526
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.18526
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
MPC FLV Splitter,0x00600000,1,1,FLVSplitter.ax,1.06.0002.4902
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.18526
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.18526
Screen Capture filter,0x00200000,0,1,ZuneSrcWrp.dll,4.08.2345.0000
PlayReady DMO Wrapper,0x00600002,1,1,PRDMOW~1.DLL,1.03.2297.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.18526
MS PR Source Filter,0x00200000,0,2,PRSource.dll,1.03.2297.0000
Haali Media Splitter,0x00800001,0,1,splitter.x64.ax,1.11.0287.0023
Haali Media Splitter (AR),0x00400000,1,1,splitter.x64.ax,1.11.0287.0023
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
Xvid MPEG-4 Video Decoder,0x00800002,1,1,xvid.ax,
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.18526
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.18526
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.18526
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.18526
Haali Video Renderer,0x00200000,1,0,dxr.x64.dll,
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
Haali Simple Media Splitter,0x00200000,0,1,splitter.x64.ax,1.11.0287.0023
DirectVobSub,0x00200000,2,1,VSFilter.dll,1.06.0003.5322
DirectVobSub (auto-loading version),0x00800002,2,1,VSFilter.dll,1.06.0003.5322
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.18611
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
Overlay Mixer2,0x00200000,1,1,,
Haali Matroska Muxer,0x00200000,1,0,splitter.x64.ax,1.11.0287.0023
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
SFVCaptureFilter,0x00200000,1,1,SmartFaceVCapt.dll,3.01.0009.0000
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.02.0000.0000
LAV Splitter Source,0x00800004,0,1,LAVSplitter.ax,0.53.0002.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.18501
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.18501
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
MPC FLV Source,0x00600000,0,0,FLVSplitter.ax,1.06.0002.4902
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.18526
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.18526
MPC CDXA Reader,0x00600000,0,1,cdxareader.ax,1.06.0002.4902
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.18526
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.18526
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.18526
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.18526
ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.02.0000.0000
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Microsoft Zune H.264 Video Decoder,0x005fffff,1,1,ZuneH264Dec.dll,11.05.7600.6740
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.18526
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.18526
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.18526
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
LAV Audio Decoder,0x00800003,1,1,LAVAudio.ax,0.53.0002.0000
LAV Video Decoder,0x00800003,1,1,LAVVideo.ax,0.53.0002.0000
Haali Video Sink,0x00200000,1,0,splitter.x64.ax,1.11.0287.0023
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.18526
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.18526
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.02.0000.0000
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.18526
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.18526
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.18526
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.18526
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.18526
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.18526
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.18526
Audio Capture Sources:
Microphone (Realtek High Defini,0x00200000,0,0,qcap.dll,6.06.7601.17514
Line (WsAudio_DeviceS(1)),0x00200000,0,0,qcap.dll,6.06.7601.17514
Line (WsAudio_DeviceS(2)),0x00200000,0,0,qcap.dll,6.06.7601.17514
Line (WsAudio_DeviceS(3)),0x00200000,0,0,qcap.dll,6.06.7601.17514
Line (WsAudio_DeviceS(4)),0x00200000,0,0,qcap.dll,6.06.7601.17514
Line (WsAudio_DeviceS(5)),0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.18526
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.18526
WDM Streaming Capture Devices:
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
WsAudio_DeviceS(1),0x00200000,2,2,ksproxy.ax,6.01.7601.17514
WsAudio_DeviceS(2),0x00200000,2,2,ksproxy.ax,6.01.7601.17514
WsAudio_DeviceS(3),0x00200000,2,2,ksproxy.ax,6.01.7601.17514
WsAudio_DeviceS(4),0x00200000,2,2,ksproxy.ax,6.01.7601.17514
WsAudio_DeviceS(5),0x00200000,2,2,ksproxy.ax,6.01.7601.17514
USB 2.0 Camera,0x00200000,1,2,ksproxy.ax,6.01.7601.17514
TOSHIBA Analog Capture (Dev1 Path2),0x00200000,2,3,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Source Filters:
TOSHIBA Digital TV Tuner (Dev1 Path0) ,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
WDM Streaming TV Tuner Devices:
TOSHIBA Analog TV Tuner (Dev1 Path2),0x00200000,0,2,,6.01.7601.17514
WDM Streaming Crossbar Devices:
TOSHIBA Analog Xbar (Dev1 Path2),0x00200000,2,2,,6.01.7601.17514
WDM Streaming TV Audio Devices:
TOSHIBA Analog TV Audio (Dev1 Path2),0x00200000,1,1,,6.01.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
Device Control Filters:
TOSHIBA Control Filter (Dev1) ,0x00200000,1,0,ksproxy.ax,6.01.7601.17514
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definiti,0x00200000,1,0,quartz.dll,6.06.7601.18526
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.18526
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.18526
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.18526
DirectSound: Speakers (WsAudio_DeviceS(1)),0x00200000,1,0,quartz.dll,6.06.7601.18526
DirectSound: Speakers (WsAudio_DeviceS(2)),0x00200000,1,0,quartz.dll,6.06.7601.18526
DirectSound: Speakers (WsAudio_DeviceS(3)),0x00200000,1,0,quartz.dll,6.06.7601.18526
DirectSound: Speakers (WsAudio_DeviceS(4)),0x00200000,1,0,quartz.dll,6.06.7601.18526
DirectSound: Speakers (WsAudio_DeviceS(5)),0x00200000,1,0,quartz.dll,6.06.7601.18526
BDA Receiver Components:
TOSHIBA Digital TV Capture (Dev1 Path0),0x00200000,1,1,ksproxy.ax,6.01.7601.17514
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
11-15-2014 11:04 PM
11-22-2014 01:08 AM
