OS: Win8.1 64-bit GPU: Nvidia GTX 970 CPU: i7-3770 Monitor(s): Single Connection(s): DK2 plugged in via GPU's DVI port using connector, monitor plugged in via GPU's HDMI port.
Titans of Space PLUS for Quest is now available on DrashVR.com
OS: Win7 64-bit GPU: Zotac GTX 980 Video Drivers: 344.65 CPU: i7-950 @ 3.07ghz Monitor(s): 3x 144hz Monitors, 2 using display ports (primary, secondary), 1 using dvi (tertiary) Connection(s): DK2 (4th display) plugged in via HDMI port Other: Alot of peripherals - attaching dxdiag report (7 usb devices that includes logitech gaming keyboard, mouse, camera, not including DK2 + camera)
I should add that I have the positional tracker and HMD connected to a powered USB hub as I could not get the camera to turn on using my onboard USB ports. I believe it is due to the hubs having to supply power to all of my other devices.
edit: updated monitor specs with current hardware
Current WIPs using Unreal Engine 4:Agrona - Tales of an Era: Medieval Fantasy MORPG
OS: Win7 64-bit GPU: Nvidia GTX 660 Ti Video Drivers: 344.65 CPU: i5-3570K Monitor(s): 1080p LG HDTV, DK2 Connection(s): HDTV connected via HDMI, DK2 connected via DVI adapter Other: HDTV locked at 60 hz
Primary system: (desktop) Windows 7 64 bit Geforce GTX680 i7-3930k 3.2GHz (hex core) with HT on Asus P9X79 Deluxe motherboard 32GB ram Dual Dell 2209WA 22" monitors (1680x1050) (both on DVI) DK2 on HDMI Aero turned off unless absolutely necessary. (I also run windows 7 in Test Mode, so I don't get all the UAC stuff annoying me. Makes drivers easier to install too)
Secondary system: (laptop, I use the DK2 on it at work) Windows 8.1 64 bit Geforce 485m i7-2760QM 2.4GHz 8GB ram 1920x1080 display DK2 on HDMI (no messing with test mode or aero, it's just default settings)
