Runtime 1.2 Sound device question
guygodin
Still waiting on hardware so I have no way of knowing if the way the audio driver works will correctly send regular Windows sounds to the headset? Can someone tell me if sounds played in Windows (music for example) will play in the Rift?
Thank you.
Virtual Desktop Developer
4 REPLIES 4
SiggiG
It won't unless the application explicitly select the Rift audio device.
CCP Games, EVE: Valkyrie developer | @SiggiGG
guygodin
Once you select it though, do you get sound from your game only or does it route all sounds to the Rift?
Thank you so much for helping out with this!!
cybereality
Level 16
I think it's only sounds from supported VR games.
guygodin
Is there a way to enable the old behavior? This is totally breaking my app. Unless I find a way to capture all sounds and pipe it to the Oculus sound device. Not something I'll have time to do before launch and considering I don't have any way to test it I'm left dead in the water....
